Are there any issues upgrading? Do existing sites need any adjustment of any kind?
If there were they have been forgotten about since transitioning to 6
He must mean 6 as I don’t think there was a 5.6 was there?
5.6.something was the last version of 5.5 (I know, crazy numbering system, eh?) and then 6 is the next “major” version.
Yes, I meant upgrading from 5.5 to 6.0.8. It seems to me that when 6 first came out there were a few issues as is normal with a major upgrade.
Generally speaking, keep using 5.5 on your existing sites and use 6 for new ones. I’ve converted a handful of my 5.5 sites to 6 without a hitch, but you never know.
What is required to convert?
All you need to do is open a FW 5.5 file with FW6. It will do the conversion itself and create a 5.5 friendly backup of your site (as 5.5 won’t open a file created in 6).
Thank you all for the help.
