You will need to save your drawings as PDF and import/convert them, but
that works for most drawings.
/Ingemar
Den 2017-02-02 kl. 20:19, skrev Phil Hendry via Intaglio:
I’ve just upgraded to the latest version, and i can’t select control points using the point selection tool. It seems to ‘click’ at a point a long way away from where the cursor is! That renders the app almost completely unusable.
I want to go back to an earlier version!!! I think I was on about 3.4 - and that worked fine!
Working on a drawing yesterday I found the click offset problem only occurred
in 100% view.
In 150% or 200% view there was no click offset.
hth… AD
On Thu, 2 Feb 2017 20:42:28 +0100, Ingemar Ragnemalm wrote:
But you can! 3.4.4 is available for download!
You will need to save your drawings as PDF and import/convert them, but that
/Ingemar
unusable.
that worked fine!
