Hello, I try to upload my site after having done some small changes. It stops after a while telling under the the moving blue line: delete stimmkunsta.gif
Then a yellow triangle and the text: can´t finish the upload, because a connection couldn´t be done. (actually it is in german: Kann upload nicht vollenden, weil keine Verbindung hergestellt werden konnte.)
What can I do? Maybe this gif-document doesn´t exist. I can´t find it on my site.
thanks for you help!
Ralf
Its more likely that FW is trying to delete that file from the server and can’t.
Can you FTP into the site and look and see if it is there somewhere - or use your Hosts File Manager.
I am afraid I couldn´t find it, but this doesn´t mean too much. I am just starting with FW (taken over from somebody else). I don´t even know how to get to the hosts file manager (using the german version without having the chance to change language.
But I tried again to upload and this time it is “delete stimmkunst9.gif” that doesn´t work. Very strange. there are several elements with a name using “stimmkunst”, most of them seem to work…
thanks for your patience
Ralf
