Further to my earlier post, I have managed to import a file into Freeway using the iFrame Action, but the URL I used to point at the file was a local one. When I upload, of course I get an error message saying the local file is not available online.
What sort of file are you trying to display in your iFrame.
If a PDF or an image then there are various actions that you can use in FW such as Upload Stuff or Extra Resources which you also you to select a file on your HD and it will then upload it to your server in either your Resources Folder or with the HTML files for the page you use it on.
If it is an HTML file then then there may well be other associated files (like images etc) that will need to be uploaded as well - and that is a bit more complicated.
And again Dave. Many thanks. Your advice this time is a bit more complicated so I’ll have read up on this topic. So far the only Action I’ve used is the iFrame. At present I’ve made use of a several jpgs to get my material on the web. It is all at http://www.khseniors.org.uk
