Hi All,
something odd going on…
my text in the designer is “£22.00 - Per Single Entrance”
but on the browser and live it’s"£22.00 - Per Single Entrance"
Thanks!!
Ok… so in I’ve opened the html file, created by Freeway, in text wrangler and I see:
Entrance is:
£33.00 - Per Joint Entrance *
but in Safari Source code view I see:
Entrance is:
So what’s going on there?!?!
And in Firefox it looks ok…
Jeremy
(Jeremy Hughes)
4
What is the text encoding set to?
(Page output panel of Inspector palette.)
Jeremy
Hi Jeremy, set to Automatic
Jeremy
(Jeremy Hughes)
6
Automatic normally outputs Unicode (which is good), but I think you probably have Safari’s text encoding set to Western (ISO Latin-1).
The pound symbol is two bytes in Unicode, but one byte in ISO Latin-1 - so the additional Unicode byte is being misinterpreted as an extra character.
Try setting Safari’s text encoding (View menu) to Default.
Jeremy
Ok… so I changed it to force Unicode and now it looks ok… is that a problem… should it be auto?
And I’ve now changed it back to Auto… and it works!!..
Awesome… than you!!
