On 17 Sep 2010 I received this message from Jo Billings related to a questions about using FVL Player with Freeway Pro 5.5:
Joe Billings17 Sep 2010, 10:05 am
[Pro] FLV Player Controls in 5.5 missing???
Hi Dan, You will need to use the old version of the Action http://www.actionsforge.= com/actions/view/190-flv-player until we can rectify the issue in the new version.
I have the same problem now and wonder if the problem with the player has been fixed for the latest version Pro 5.5.4?
Also what will be the best way to convert the movie for Freeway usage and with what program? also what format will be best?
And if I use the flush player how can I get different looks and controls? Freeway offers just one option (Quick time) and that is so ugly
and unpractical.
A lot of questions above. Thanks for taking the time to answer.
Yep, should all be fine now. If you need an immediate answer to questions like this you might be better off looking at our release notes on the KnowledgeBase: Docs - Softpress Talk
On 9 Mar 2011, at 20:47, Dan Demetriad wrote:
Hello people,
Isn’t anyone out there that can answer my questions???
What happened to you Jo Billings? Was the problem rectified since September last year?? this is a question that can be answered easily by yes or no.
Still waiting for the good soul that will help me with this FVL and quick time being used in Freeway.
Dan
I’ve tried the old and the new Action for FLV and using iPhone/iPad compatibility. It simply won’t work. I’ve even tried converting the QT Files from QT Pro to iPhone/iPad/iPod Touch compatible. Then pointed the FLV Action to those files. Still won’t work. Flash plays it fine, but iPad and iPhone simply sees nothing but a blank box…
I’m open to tips and suggestions to make this work. Although I think I saw a post around here that its still a broken function for now.
