I’m trying to use an itemref control to select label items associated with checkboxes under Freeway 6. Unfortunately Freeway is only returning the parent div and the checkbox itself in the resulting menu. Other than making and populating the menu myself manually is there any way to force the itemref to return a reference to the label object?
For example;
will retur a menu;
item1 ← the parent DIV
item2 ← the checkbox
It would appear that there are certain items in Freeway that can’t be accessed like this. Horizontal rules are another.
Labels and rules aren’t FWItem objects so won’t show up in itemrefs.
If you’re working on something that adds data to label then it would be worth getting the user to select the input item and then looking for the label in the output to see if there’s one there. A couple of things to note: inflow checkboxes and radio buttons don’t automatically generate labels and labels for an input item aren’t necessarily parents of the input item.
Does a label show up as a tag in the fwDocument.fwTags? You may be able to select the checkbox and then work backward at the time of publishing. Trouble is, it is perfectly legal for a single form element to have more than one label associated with it. The for attribute isn’t page-exclusive in that direction, just the id in the opposite direction. This may be a non-issue in a normal Freeway layout, though.
On Feb 17, 2014, at 9:59 AM, Joe Billings wrote:
Hi Tim,
Is there any way that I can detect if something like an HR is present at design time (so before the page is published) so I can offer this as a target in the Action UI?
Thanks in advance,
Hi Walter,
Yes, I can get to the tag at publish time without issue. My issue is that I wanted to offer a UI that reflected the state of the item the Action was applied to so allowed users to select the item to target. I may have to rethink the interface a tad to make it a little more generic.
