I have 3 graphics that I’m using in sequence to trigger the appearance of the next graphic. In addition to using the Rollover, Target Show/Hide Layer, and Sound FX, I’m using Transition FX.
I’ve delayed the appearance of the 1st graphics appearance using On Page Load with it initially being hidden. I also use the On Trigger to remove the graphic when it is clicked.
Graphic #2 appears as it should being a Target, but the Transition FX behaves differently. Specifically, the Delay seems to have no effect. I get #2 to fade in and out (to #3) just fine, but I’d like to add an appropriate delay as with graphic #1.
Is this a limitation of Transition FX, or is there something I’m missing?
