Peter2
(Peter)
1
Hi,
I’m trying to add a booking button to a clients website using timely. But when I add using html markup nothing happens.
the following is first info from timely:
Make sure this snippet is included once on your page (ideally in the head but make sure it is before the button snippet).
I’m adding this to before on page html markup
second instruction from timely:
Add this snippet where you would like a button to appear. You can add as many buttons to a page as you like.
I’m adding this to markup item
anyone know where code should be going?
thanks
Peter
waltd
(Walter Davis)
2
On Apr 26, 2016, at 7:09 AM, Peter email@hidden wrote:
Hi,
You should put this in the “Before End Head” Before </head> picker option.
This looks fine, if you do the former. Also, if you are going to use a script tag without the type attribute, make certain your page is in HTML5 mode.
thanks
Peter
And if you are having no success once you have done this (and uploaded) then post a link and we can have a look.
Note that the timely script code link requires a live site.
Peter2
(Peter)
4
Thanks Walter, David will do.
