V-card
Good morning - how do you add a v-card to a site for clients / visitors to see / use
thanks
Julie
What is a v-card?
see / use
thanks
Julie
file for electronic business cards
vCard is a file format standard for electronic business cards.
On Jun 19, 2013, at 8:27 AM, Ernie Simpson email@hidden wrote:
What is a v-card?
see / use
thanks
Julie
Hi Julie,
  1. Right-click on an Address Book entry and choose Export V-card.
  2. Attach the v-card file to the Upload Stuff Action (FreewayActions.com | Upload Stuff) and use the Upload to HTML Location option
  3. Create a normal link from a graphic or run of text using Edit > Hyperlink > External tab and enter the v-card name into the dialog
Now when the user clicks on the link the v-card will wing their way.
Here’s one I made earlier (as all good TV chefs say);
http://www.timplumb.com/
Hi Julie,
You should be able to link to the .vcf file using the Link to File Aciton (or Graphic Link to File if you’re applying it to an image), or upload the .vcf to your server and link to it manually. The thing to look out for is your server not knowing what to do with it so take a look here for details (basically you need to add the vcard MIME type to your server so it doesn’t just try and display it in the browser):
http://www.thesheep.co.uk/2007/06/15/forcing-vcard-downloads-on-the-web/
What is a v-card?
see / use
thanks
Julie
Thank you both! I will work on it.
Julie
On Jun 19, 2013, at 9:44 AM, Joe Billings email@hidden wrote:
Hi Julie,
What is a v-card?
see / use
thanks
Julie
Ah, I was thinking of hCards -
http://cssway.thebigerns.com/workbench/hcard-vcard-microformats/
What is a v-card?
to
see / use
thanks
Julie
sorry for the late reply
This worked perfectly!
thank you!
Julie
On Jun 19, 2013, at 9:42 AM, Tim Plumb email@hidden wrote:
Hi Julie,
