On 3 Nov 2006, 7:23 pm, The Big Erns wrote:
thebigerns.com
I just downloaded this document and gave it a spin. I myself am trying to achieve a flexible layout design WITHOUT resorting to inlines, so this example is very nice. However, I found that the example presented in this document breaks when you merely apply a border to the parent box (the one named “parent” in the FW document). If you apply a border and then Preview, the border appears but then there is a copy of the content that is cast down beneath it.
I currently have an example page here:
http://kiramek.com/newz/japanese/aboutus.html
Notice the 2 curved corner boxes in the center of the page. The gray background behind those boxes is actually a single large layered HTML item with a gray color applied. I then drew those two layered HTML boxes (with curved corners) as children of the big gray box. I then drew non-layered HTML boxes inside those curved-corner boxes, in which I put the text. I then set the non-layered boxes to have height that can shrink. This works a little bit to add flexibility to the layout if the text size changes, but the boxes overlap eachother of the text gets too big, and the lower box doesn’t shrink vertically if I shrink the text in the browser.
So the ultimate aim in my mind is to find a way to make boxes with borders and curved corners be vertically flexible in size, according to the text content inside. And again, if this can be done without resorting to an inline/inflow layout, it would be desirable.
Thoughts?
–James Wages
