David, as always, thanks for helping me with this confusion I had.
This PHP feedback seems much easier…
Thanks for the table example also.
best,
Marcus
On Mar 11, 2011, at 6:33 PM, DeltaDave wrote:
Another tip for form building.
It will help to give you a far neater form layout if you use a Table to hold your form elements.
A 2 column table with enough rows to have each field on a different line will keep everything together.
The first column should have your Titles ie Name Email Address etc while the 2nd should contain each individual form element. This page shows the structure I normally use - I have left borders on the table cells to better illustrate the construction. These would be hidden in a production version. http://www.deltadesign.co/formtest.html
