Ha! well Walter I put the? instead of #
and the image slid all the way to the left instead of right.
what is that?
what is that?
here you go Walter
I uploaded screenshot of the link using the ? instead of # ann the opposite happened…
image still not centered
http://carlagrande.com/Listbot/
Walter problem solved!
sometimes I do figure them out!
I had the link to the graphic box and not the html box
hmmm
what a dunce!
C
This will be down to how you have constructed the panes. Each one
needs to be a DIV (HTML layer) with all of its sub-parts positioned as
children.
To do this most easily,
See if that helps.
On Jun 25, 2009, at 10:16 AM, Carla wrote:
here you go Walter
opposite happened…
image still not centeredhttp://carlagrande.com/Listbot/
grrrr
one more point
the use of # for anchor is best. It points directly to image.
The ? sends it to the page as it scrolls and it is not a nice way to land on the page
just my 1 cent
thx for patience
C
Depending on whether your carousel is within the first “page” of the
screen height or not, the anchor can work well. But in many cases,
using the anchor rather than the query causes the entire page to shift
down to the top of the carousel container element, scrolling down past
your navigation and so forth. In those cases, using the query provides
a neater appearance.
On Jun 25, 2009, at 10:57 AM, Carla wrote:
grrrr
one more pointthe use of # for anchor is best. It points directly to image.
to land on the pagejust my 1 cent
thx for patienceC
Thanks Walter
My carousel is perfect
this was not the problem. it was user error as far as the link
only. I pointed to graphic box instead of html box
grrrrr
thanks
pardon my ignorance… what is query?
I use anchor right?
not to complicate matters
C
In a URL, anything following a question mark is known as the
‘QUERY_STRING’ to PHP and Apache, the ‘search’ to JavaScript, the
‘querystring’ to ASP, etc. It’s a distinct part of the page URL. I
refer to it as a query, synonym for question, because of the question
mark in it.
I use anchor right?
C
