Is it possible to create a webpage shadow and rounded page or box corners with Freeway Pro, similar to this website?
http://www.fantasypros.com/
If so, how is the accomplished?
Kelly
Yes - but IE browsers less than IE9 may not see it.
There are a couple of actions available at actionsforge.com CSS3 Shadows and CSS3 Corners part of the CSS3 Goodies action suite http://actionsforge.com/projects/view/78-css3-goodies
You will ideally need to create inline content so that the expanding content will push the footer down.
Alternatively you could use graphic boxes with rounded corners behind your HTML content but it may all fall apart at different text sizes.
Thanks Dave. I just tried this using a blank HTML layered page sent to back and then applied a white background with an outer glow graphic effect set to black with 75% opacity and a blur of 6.
That seems to work pretty well. Will that be seen in most browsers?
Post a link and we can have a look.
But if you are just using graphics for this then yes it will be seen cross browser.
I will when I upload it later this week. BTW, do you have an iMac i5 or i7?
Neither. Intel Core 2 Duo
