The people from the school I make a website for wants to have the possibility to select several images in once to make an image gallery ? I don’t think this is possible with Webyeb at this time ?
Hi bart
I cant see how you could integrate one to the other so unless I have missed something or there is something there not telling us over at the visual slide show website then I would probably say: no can do :o(
All by themselves, Web forms cannot upload more than a single file at
a time. There are two alternatives – use a Flash or Java based
uploader applet, or Zip the files and have the server unzip the bundle
into its component parts. I have used both techniques, and they have
their ups and downs. The former is fiddly as all get-out to get
working, and then relies on the end-user having their computer
configured a certain way, which is never a good bet in a public Web
site. The latter relies on the user knowing how to Zip a folder, and
understanding that he needs to. See the former for the conditions
surrounding that.
On Sep 22, 2010, at 2:43 AM, Bart wrote:
Thank you Max. Is there an another way that makes it possible to
select multiple images at once to make a slideshow within Webyeb?
