Webyep loop within a loop
I don’t know if it’s possible…but can you put a loop within a loop in webyep?
Basically, on the sidebar under downloads (in the example page below) I have a blue box containing a heading and an attachment, which is all one loop. I need to be able to add multiple attachments under each of the headings.
I have tried to put another loop just around the attachment to create a loop within a loop; however when I do this the bottom of the page just gets cut off. I’ve tried wrapping the extra loop in and out of its own seperate html box.
Thanks for any help…
Steve
http://94.136.40.103/~cheaper-school-prospectus.co.uk/laroche/welcometochelten.php?WEBYEP_EDIT=no3862&WEBYEP_FIELDNAME=LoopStart-2&WEBYEP_GLOBAL=0&WEBYEP_PAGEID=1&DOC_INST=0&WEBYEP_LOOP_ID=3&WEBYEP_ACTION=LOOP_REMOVE&WEBYEP_ACTION_ID=252
No you can’t. The best you can do it to create for example say 10 slots for downloads. Any that aren’t used won’t publish so wont take up any space.
David Owen
Printline Advertising
It might be that in the longrun there are more than 10-20 attachments needed for some of the headings but for now it looks like that’s probably the way I’ll need to go. Thanks for the advice David.
Does anyone know if there is another method that might work?
Steve
Update…
Just tried adding multiple slots within the loop for the attachments but on testing they all just populate with the same attachment.
Aghhh?
Are they named differently? I made this mistake by copying and pasting the original.
On 26 Feb 2014, at 16:40, Steve email@hidden wrote:
Update…
Aghhh?
Yeah…I just realised that I’d named them the same - I’ve changed their names and all good! Doh!!!
Thanks Trev.
