On 13 Nov 2019, at 14:57, Sjef Broere via freewaytalk email@hidden wrote:
On 22 Jan 2019, 11:21 am, Richard Lowther wrote:
Ok I have found and downloaded WebYep 2 from GitHub. But I am still looking for the actions -3.5 - and the Commercial Version. Any clues anyone ?
I appear to have actions 3.4 installed - will they work with Webyep 2 ?
And how do I do resolve the php question - will that just work once I have got Wepyep 2 and all its actions installed - on existing sites as well as new ones ?
Hi there folks, I too am looking for the Freeway 3.5 Actions. There’s no version number on the site, so I’m worried I’m re-buying the ones I already own. Are they the 3.5 ones?
Hi everyone who have purchased webyep actions in the past
i haven’t released 3.5 (the latest) cos I was still working out 1 conundrum which was to do with loops and ids.
In the past, I added the facility to remove an id from a looped item and that item then used those styles and applied them as a class or inline
in Freeway 7 that all changed.
In fact, I made along with an enormous amount of help from Walter tim paul … basically everyone an action that did a proper job of converting ID styles into class styles and still have the responsive styles also work… to cut a long story short… it was a blooming nightmare to get it to work properly… so I was t a point of… is there any point in me adding that into webyep freeway actions… (lot of work) or just say to people if you are uisng Freeway 7 then don’t use the “if loop item” checkbox within a webyep item. but alternatively use the action that was made specifically for converting ID styles to classes styles.
although this sounds fine the downside is I am going to be inundated with support questions over this… so hence the conundrum … do I plough more time into a set of actions that ultimately need to be redone all over again for xway
Justin if you want to email me directly I can sort something out for you
max
