i’m using max Webyep actions set for a long time and was totally satisfied with it.
Since i have upgraded to Freeway 7 i have lots of issues.
I made an artwork using Webyep and Carousel 2 together.
Both Image and text actions don’t work anymore.
I tried to rebuild the all stuff using Carousel rather than Carousel 2, same problem.
I convert another previous artwork using WebYep and Carousel from Freeway 5 to Freeway 7, same result.
I feel very disapointed cause i cannot say if there is a real problem using these two actions together or if i made a huge mistake.
Hi Alain
I have just a few questions…
Which version of webyep actions are you using is it 3.4?
Where is your webyep system I did a quick test and I could find it in the root of your server?
Have you tried to create a new document and seen if a new document works with the method you used to create your old artwork?
if you have an old pre 7 artwork could you send me the freeway artwork and I will see if I can covert it
speak soon max
thanks.
WebYep 3.4 and webyep system 1.7 installed on my server.
What i have tried :
-totally rebuilding the artwork after removing and re-installing WebYep actions.
-rebuilding it after having removed carousel actions to see if there is a conflict between your actions and Carousel.
-open another artwork previously built with Freeway 5.4 and try to make some change on it.
-Building a brand new project based on the same drawing, once with Carousel version 1 and then with version 2.
There is clearly an issue when trying to upgrade an artwork from Freeway old version (5.4) to Freeway 7. Then, or Carousel or Webyep don’t work anymore.
I have kept the old Freeway 5.4 version on my computer and the two versions of Carousel in the actions folder.
Do you think it could explain these issues ?
I will send you some screenshots to show how it looks.
Speak soon.
