Hi everyone this really should have gone in the off topic area, but because its a warning then I thought I better add it to this part of the forum.
OBD have updated there webyep-system from 1.4.0 to 1.4.1
yipeee I here you cry… well there is one small warning.
Unfortunately this latest version of the webyep system doesn’t honor the webyep-image styling method which I use and so do many others so if you have used the “Optional arbitrary HTML attributes/values” field to style your webyep images then please don’t upgrade to this version until I can find out if this is a bug or if this method of styling is now not supported any more
A lot of people don’t and have never used this field and for those that don’t then this problem has no effect. On those people that do use this method, you will find that the styling does not work, so things like: floats and clears or borders and margins will not work.
For those sites that are effected please use the 1.4.0 webyep system for the time being…
All the best and I will keep you posted
byyyyeeeeeeeee
:o)
