Sometime around 25/1/09 (at 09:00 -0500) tok said:
I don’t remember, I am afraid. And - even if I did - would a client care?
Possibly not, but that isn’t really the reason you do this kind of exercise.
If you think it might take, say, 40 hours to
build another site like the one you did before,
then you can start to work out how much you
should charge. This is only part of the equation
of course; next you need to work out how much you
should fix as your bottom-of-the-line hourly rate.
It doesn’t matter whether you present all the
details of this sort of process to the client or
give them a single figure, this is important
stuff to do.
If you charge less per hour than your basic
income requirements then you are effectively
subsidising the client’s site by giving them some
of your own time. There’s nothing wrong with
doing this… BUT you shouldn’t do it without
deciding to.
As for working out your minimum hourly rate, this
is not quite as hard as it might seem, and
moderately scientific. This applies whether
you’re doing this as your full-time job or you’re
doing it in your free time.
Work out your base-level gross income
requirements. Include everything required to
cover rent/mortgage, transport, food, clothes,
bills, software and hardware, holidays, evenings
at the cinema, income tax (remember this is
gross, pre-tax)… absolutely all you need to
maintain yourself and any dependents in a
reasonable manner.
For the sake of simplicity let’s say this is
£40,000 per year. In reality it may be more or it
may be less; this is just an example that I’ve
used before.
Divide this by the number of billable hours you
can reasonably expect to have IF you did this
full-time. (This process works even if you’re a
salaried employee somewhere because hours taken
for freelance work are hours taken from the rest
of your life, regardless.)
To save you the headache, a reliable (and also
mathematically-convenient) figure for this is
1000 billable hours per year. The other 1000
hours in a typical work-year are typically spent
on non-billable stuff. (Sad but true, trust me!)
So the final equation is this:
(Total required gross annual income)
divided by
(annual billable hours)
equals your minimum hourly rate.
Expressed with the example income requirement above, this is:
£40K / 1000 = £40ph.
Now you need to decide whether you’re going to
build in anything for negotiation room or to
allow for slippage. If you were dealing with a
more specialist area such as server-side
scripting with PHP and MySQL then the norm is to
charge significantly more than the above example
figure, so having worked out your rock-bottom
rate you need to see if you’re undercharging
compared to reputable (I stress reputable)
competitors.
If you think you’re overcharging and you don’t
feel comfortable charging your base-level hourly
rate… then don’t take on the work.
Seriously, if you charge less than you NEED then
you are effectively paying for part of the
client’s site yourself with your time. If you
want to provide your services as a charitable
donation, fine, otherwise Do Not Do This.
(And if you DO donate time in this way make this
known to the client - or you will eventually
regret it as people start taking you for a ride
and walk away the moment you ask for a reasonable
price.)
Finally, I prefer not to talk about hourly rates
if I can help it. I would rather talk about the
cost for a project, or perhaps daily rates if
necessary. But knowing your minimum hourly rate
is helpful when working those things out, of
course.
k
