Bill7
(Bill)
July 6, 2015, 6:43pm
#1
I used Yummy FTP and dragged and dropped all the file over and it looks like this.
When you click on Site Folder it goes to the website
but the first shot is not showing the pages with just the list of links.
I hope this makes sense?
bill
http://test.thevst.com
Bill7
(Bill)
July 6, 2015, 6:55pm
#2
More information.
I dragged and dropped file with Yummy FTP and my WowSlider works.
When I looked at the files and index.html was missing so I went to Freeway and uploaded the files thinking it would fix it.
Now the WowSlider is not working.
This test site is a different web host from the last one I was working with so I’m a little confused.
Your help is greatly appreciated.
Bill
Why aren’t you using Freeway to upload your files?
David Owen
http://www.ineedwebhosting.co.uk
Bill7
(Bill)
July 6, 2015, 7:37pm
#4
Because the Wow Slider has to have manually uploaded folders
data1
engline1
to make it work.
So I upload through Freeway and with the old test site I would just manually put those folders through YummyFTP. It’s not working this time.
I am getting a 404 from this link - findresults.site
That tells me that the engine1 folder is not where it should be or the files/folders are not correctly named.
Check where you have uploaded these files/folders to.
Bill7
(Bill)
July 6, 2015, 10:16pm
#6
I wish I could take a screen shot and attach it so you can see my ftp files and where they are.
Well - basically it’s a path issue which will mean:
All files are connected (in your markup) to a place e.g.:
http://test.thevst.com/engine1/jquery.js
which will mean, that the “engine1” folder (the correct names assumed???) is expected in the main root, alongside the rest of the files. Error 404 (not found) means there isn’t any.
Attaching images is possible. I place them in my dropbox public folder, visiting this site: http://daringfireball.net/projects/markdown/dingus taking the snippet:
and substitute the path to the image (aha - paths!!!) by the copied link to dropbox like so:
That magically makes images appear and looks like this:
PS: Once created Reginald for later use - but totally forgot about him.
Bill7
(Bill)
July 7, 2015, 4:46pm
#8
Thank you! It worked.
I am so appreciative of everyone’s help for someone like me who doesn’t know much.
Bill
