Christoph
(Christoph)
October 6, 2008, 2:08pm
1
hi,
i build up a side and on my safari it seems to be perfekt. But when i try to use the side on IE the font ist munch bigger and some elements did’nt fit on the page.
Thx,
Christoph
Are you using pixels to set your font sizes or relative sizing (small, medium, large etc.)
The pixel method will translate better across different browsers.
Christoph
(Christoph)
October 7, 2008, 6:19am
3
Hi David,
i’ am using pixels - just have a look on page http://www.praxis-sonnenberg.info/ueberweisungen.html
I move the buttons more then 50 pixels down because the textfield overlaps them on the IE. Sometimes the page is to short on the IE.
How can i avoid this?
Thx,
Christoph
