Oh dear- I’m sure we’ve been here before- but is there an easy way to remove the white background from a piece of clip art?
This is something which causes aggro to me every day. I teach children to make say, a nameplate for their bedroom door. And then the girls want to put a dog on from “Art Explosion” (Nova) and we can’t remove the white rectangle.
Is there an easy, child-capable (as it were) answer?
It depends. How white is the background? If you want a simple answer,
the magic wand tool, in Photoshop that is. However, if you have a
complex background, you may be fussing around for an awful long time.
Choose “inverse”, then save as a png or a tiff, but not as a jpeg,
because jpegs can’t handle transparency. Hope that helps.
regards,
Tom
If you have a mac, you can remove colors using Preview (comes pre-
installed). In the toolbar at the top, choose select and then “instant
Alpha.” It’s best not to try and remove everything in one swoop, just
work with a small section, delete, then repeat. Not photoshop, but
works surprisingly well for many photos.
John Akin
I should have been more careful with my steps—it’s actually the
sidebar that opens up a toolbar. I’ve uploaded a PDF to my dropbox
which outlines the steps. This link will download a screenSteps PDF
(862KB):
For images with white backgrounds, the ‘Mask White Image Pixels’ Applescript makes the white areas of JPEG images transparent. This doesn’t work with TIFFs.
There will probably be white halos around the edge of the cut-out image and some parts of the picture (which you want to keep) might/will probably disappear.
iMaginator’s ‘Mask by Color’ feature erases a specified colour. A Precision slider controls how much is erased. This is fun to use, but a bit fiddly.
For more control, choose Intaglo’s Path tool and draw a path around the target image (the bits you want to keep), select the path and image and choose Group (Image menu). Open the Group palette (Window menu) and choose ‘Standard’. The background disappears.
It’s in the Scripts folder.
Go to Intaglio’s top menu bar and press the icon that looks a bit like a 3D ‘S’. The Scripts folder opens. The Make White Image Pixels script is in there. Double-click it and when it opens in Script Editor, press the Run button.
