Why is my shadowbox not working?!?!?!
I have pasted the right code before /head, I have created rel=shadowbox for each image, but the images are just opening in the window instead of using shadowbox:
http://mmsies.com/clients/DaveLiebman/OneSheet/daveliebman-phot.html
I am pulling my hair out. Any ideas? Thanks in advance.
TB
I’m not sure if there is another action or function called shawdowbox, but the light box action(s) are easy to use and should help you reach the desired effect.
Try the Moo Slimbox action,
http://actionsforge.com/actions/view/90-mooslimbox
Or the ScriptyLightbox action,
http://actionsforge.com/actions/view/153-scriptylightbox
No messing with code required, just draw your thumbnails and apply the actions according to their directions. Just don’t try to use both actions on the same page. I’ve never tried it but apparently the world will end if you do.
Or the new gallery/showcase tool in 5.5
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
ScriptyLightbox - ActionsForge
May well be to do with the fact that your file sizes are huge 1.4Mb for some!
Also the pixel dimensions are all over the place
4.jpg is 3872 × 2592
Resize your pics to something more sensible - like 800 x 536 and 72dpi for this one and it will get the file size down to 85kb
Sorry ppi
ScriptyLightbox example http://www.deltadesign.co/scripty.html
Big picture is 53kb
Thanks to all for the suggestions! I figured it out- the shadowbox javascript doesn’t function properly if you have added graphic effects to object, such as an outer shadow. I’ve actually found this to be a problem with other things in Freeway as well.
I’ve added new graphic boxes behind the pictures and added the shadow to those instead- just to get the desired effect. All is working fine now. Thanks again for all of the input.
TB
Still got those massive file sizes!
