once again i’ve a question about the web yep action suite: i inserted the “read more” action into a loop. now, when a new loop object is added and you click on the read more (Mehr…), the appearing popup window is already filled with content from another product and not blank as it should be.
Hi Ray
have you added the loop start and lop end in correct place ?
I would need to look at your freeway constructed page to be sure so if you can can you send it through to me on my izzat address
Hi Ray
Now I can see whats happened.
The readmore link is a way of creating a new page/instance but its limitation is that if you target the same readmore page from different pages then the result is you will see content that been generated by other readmore links from different pages…
So the way to get around this like this
The topseller.php page’s readmore more link points to a topseller-product.php page
The angebote.php page’s readmore link points to a new readmore target page and that one can be called angebote-product.php
The sonnenpflege.php page’s readmore link points to another new readmore target page and that one can be called sonnenpflege-product.php
I hope that makes sense but if not let me know
max
