I spent a few hours today playing with the Xweb b1 beta and other than an odd (editing text) hard crash the application did well. I’m still trying to get my head around the interface and specifically the inheritance of styles. I’m sure I’ve created a less than optimal set of CSS!
Overall I think this is a good idea as it forces you to think about styles much as they are used online.
My biggest concern in that a lot of Freeway users (especially Express users) have grown used to creating their web pages like a painting; placing elements where they like, sizing them how they want and styling the elements as they see fit. This care-free approach to web design can be great and is one of the things that made Freeway so very popular back in the day. Xway, by its very nature, is a more considered environment and makes you think about layout and styling from a right brain perspective. You can’t (for the most part) just drag and drop stuff on your page, style it and hit publish.
Don’t get me wrong the web has matured and web design is more than just table based layouts these days but I’m concerned that the structured nature of building a page in Xweb will be a turn off to users who still expect to design pages in a DTP-like fashion. Still, maybe these people are using Blocs, WordPress and Divi or something similar where they can assemble their sites from a selection of prebuilt components.
Anyway you can find the output from my afternoon’s play with Xweb here with a download link to the file at the foot of that page.
The problem with this approach (putting stuff anywhere you like) is that it creates fixed-size pages that don’t adapt to different devices. We abandoned this kind of layout with our Freeway 7 templates, but Freeway made it difficult to do inflow layouts - I generally recommend that users start with a template and see if they can adapt it.
If someone wants to place items anywhere on the page, they can do this with Xway:
Change Position to Absolute
Place the box anywhere you want on the page
This is equivalent to using “layer” items in Freeway.
It probably won’t look good, even on desktop browsers. Absolute-positioned items are taken out of the page flow, so they don’t adjust to take account of changes in size and position that affect other items.
On Thu, Nov 7, 2019 at 10:37 AM, Jeremy Hughes wrote:
That looks good - well done!
I’ll download your document and take a look at it tomorrow.
You probably know that I’m not adverse to shoe-horning things in that aren’t currently supported yet so watch out for scripts that load stylesheets and jQuery (in place of HTML markup) as well as extra code to replicate the columned output (header and footer).
Expect it to be a mess and you won’t be far off. Hopefully the more I use the app the more things will make sense.
Nice work, Tim.
For me, it’s going to take a while until I get used to Xway, to make something like this as I was used to do in Freeway 7, but yes, as Jeremy mentioned, using a template will help a lot
Best,
Marcus
Xweb certainly shows promise but b1 is still a little too lacking (for me at least) to do any real work with it. I found it a little like working with Express in that I had to be a little bit creative about adding things to the page that the app didn’t support. Those will come in time I’m sure.
A couple of things that I spotted that I think could be improved on are;
The CSS Markup and JavaScript Markup areas are tiny! I didn’t add to much to these but found myself having to copy and paste the code in from a text editor as I couldn’t manage editing the code in those areas. I’d suggest replacing the text area for a button that either opens a sheet or a file in an external editor. Extra points if you can use the Freeway trick of underlining the button text to show if there is content in there.
The ± controls for the Para and Span Extended Properties and Attributes don’t display. They appear to be there as you can click where they should be and the app pops up a welcoming Name/ Value bubble (I’ve never seen inputs in a bubble before). This is more of a bug than a suggestion.
I think we expect people to copy/paste code from a text editor (that’s what I do). Xway (in contrast to Freeway) tries to avoid being excessively modal, and sheets are a modal option - you can’t do anything else in that document until you dismiss the sheet. Having a text view (that can display at least part of the markup and which allows you to copy/paste all of the markup) seems like a better option than having a button (underlined or not).
On Fri, Nov 8, 2019 at 04:31 AM, Jeremy Hughes wrote:
I’m not doubting you - just looking for a way to reproduce the problem!
Does it happen in a new document?
Can you provide a simple series of steps?
Does anyone else see this happening?
I haven’t run Xway in High Sierra recently.
I’m sure you’re not.
I just tried this on a new document (same Mac) but still get invisible + - controls for those elements.
Incidentally how can I edit the name field once added? I can edit the value without issue but the name is set in stone.
I can send a screenshot if you don’t believe me!
Thanks.
You can’t edit the name field (currently), because mostly you wouldn’t want to change an attribute into a completely different attribute and have it retain the same value.
If you make a mistake, it’s simple to delete the attribute and create a new one.
Unless the result of “editing an e-mail” is to send a new, corrected e-mail, I don’t know how this system will integrated 1:1 with the mailing list feature if it allows direct editing.
On Nov 12, 2019, at 1:25 PM, Tim Plumb email@hidden wrote:
Thanks. I only get the option to ‘save and send to group’. Maybe the silent editing is an admin option.
The Swift forums (using Discourse) are like this. If someone edits a post, it doesn’t get re-sent.
You don’t see a “Save Without Sending” button (immediately after “Save And Send To Group”) ?
