I’ve just pushed a new set of the following Actions to ActionsForge.
These Actions are backward-compatible with Freeway 4 and 5, but
include updated versions of the Prototype/Scriptaculous libraries in
order to work correctly with Freeway 5.5’s bundled FX and Target Show/
Hide Actions.
In the Protaculous bundle:
Protaculous 0.6.5
Observer 0.2.5
Carousel 0.2.5
Carousel Pane 0.3.5
Carousel Button 0.9.5
Carousel Text Tab 0.2.6
Carousel Tab 0.7.5
Separately:
CalendarView 0.4.7
ScriptyAccordion 0.6.5
ScriptyLightbox 0.3.9
If you are using Freeway 5.5, please update to the latest versions
today!
This confuses me a bit. If we are using the freeway installed actions that
came with 5.5, can we not just wait till Softpress releases an updated
version of 5.5 with these updates included? Or are we at some risk staying
with the baseline software and its built in actions?
Bill
On Wed, Sep 22, 2010 at 6:23 AM, Walter Lee Davis email@hiddenwrote:
I’ve just pushed a new set of the following Actions to ActionsForge. These
Actions are backward-compatible with Freeway 4 and 5, but include updated
versions of the Prototype/Scriptaculous libraries in order to work correctly
with Freeway 5.5’s bundled FX and Target Show/Hide Actions.
Protaculous 0.6.5
Observer 0.2.5
Carousel 0.2.5
Carousel Pane 0.3.5
Carousel Tab 0.7.5
Separately:
CalendarView 0.4.7
If you are using Freeway 5.5, please update to the latest versions today!
These Actions are my own product, separate from the core Actions. If
you use any of the core Actions, and you want to also use my Actions,
you have to update my Actions to remain compatible with Freeway 5.5.
If you don’t use my Actions, you certainly don’t have to update them.
actions that
staying
Bill
ActionsForge. These
updated
correctly
Protaculous 0.6.5
Observer 0.2.5
Carousel 0.2.5
Carousel Pane 0.3.5
Carousel Tab 0.7.5
Separately:
CalendarView 0.4.7
today!
Hi Tim,
It seems to be happening only one site only after I updated Walters new updated versions here. All errors are to do with Target Show/ Hide Layers, a mountain of them.
The javascript error reads:
varkfileNotFound=fwGetString(“The file”^0^1"was not found in the Action bundle");
Do you want me to send all the files in this site to support ( very big ) or just some pages? Many thanks, Pete
Try the usual trick. Edit/Resources (from the main menu), then click
on the Resample All button. It sounds like a path has been shifted
somewhere in this document. One way to be certain is to create a new
document from scratch using both of the Actions. They should work
together without issue.
On Sep 23, 2010, at 10:52 AM, Pete wrote:
Hi Tim,
Action bundle");
