Take a look at Affinity Designer. I’ve found all the features I needed,
and it’s been just as simple to use for me. While they don’t yet
specifically list Bug Sur compatibility, the product is popular and in
active development.
As a long-time Intaglio user who was thrilled with the app, I’ve finally
accepted it’s abandonware for whatever reason. I definitely got my
money’s worth, and it was a great app - but I had to move on. I hope all
is well with the developer.
Ooh, I forgat about Designer. There’s a free trial too so may be able to
test for imports before buying. I already have Affinity Photo and that’s
excellent.
“Inkscape doesn’t list dimensioning and scaling in its feature list.”
It has - even dynamically updating as a path-effect or with the “measurement-tool”. I have pretty much all Vector-editors available for macOS - I was lured when Serif promised AD to open Freehand files - which was a joke apparently. There are nice features and the UI is more modern - no question - but it takes just a few minutes and I´m back on my working-horse and that is a native Inkscape version from 2015. The latest native version 1.0 and 1.0.1 introduced to many issues regarding converting text+shapes+Boolean-operation. The feature set is unparalleled imho. I have no clue what happened to Nick Nallick - hope he´s fine - not talking to his audience; not so cool.
I enjoyed Intaglio for more than 15 years and will keep it in my toolset. I find nothing opens quicker and is easier for annotation imagery - just my 2¢.
Intaglio mailing list
Can you put dimensions on an Inkscape drawing? For example, like an architectural drawing or an engineering drawing?
Hello,
I had tried EasyDraw many many years ago, I found it was a fine software but I preferred and had bought Intaglio. Now Intaglio is almost dead. The question : how long will Affinity Designer be living ? how long X-draw ? Or Y-draw ?
Jacques Villars
rue des Moissons 97
CH-2906 Chevenez
41 32 476 64 77 fixe
41 79 381 10 23 mobile
Le 24 sept. 2020 à 07:46, Frank email@hidden a écrit :
Affintiy designer has a nice modern interface but does not have the ability to draw to scale or do measurements or dimensioning. It’s strictly for drawing for graphic design, not drafting.
I really hope that Intaglio is not dead, it’s a great program!
I am one of those who, regrettably, have to plan a migration from Intaglio towards a Big-Sur-compatible alternative. I am looking into Affinity, here is a brief list of things I had to learn in the change from Intaglio → Affinity:
• duplicate: cmd-D —> cmd-J
• line tool —> choose the pen tool and select the line mode
• Apple color picker can be found in the View menu
• cmd-arrow —> shift-arrow (displacement distance can be set in the tools section of the preferences)
• to rescale by a certain percentage, say 150%: replace input field in the transform panel by 150%
• there is no arc tool
• there is no “select similar” functionality
Intaglio appears to be back! I’ve updated to MacOS 11.1 and have no problem opening the program, old files, new documents, using tools, etc. I haven’t conducted an exhaustive test, but so far so good. I’m using a 2016 15" MacBook Pro. I had purchased XDesign as an alternative. It had a few advantages over Intaglio, but also some glaring omissions. So glad I can stick with my trusty friend for a while longer.
I’m running Big Sur 11.0.1 and can use Intaglio 3.9.5 almost without problem.
I have some maps with large page sizes (eg 1500mm x 1200mm). When I open these documents I lose my page size and just get US Letter. I can reset this as a custom page size but, after a save and reopen, I’m back to US Letter.
Wonderful app. I like it so much, I’d pay money to see it receive ongoing maintenance.
Mike
Perhaps we are all worrying too much. Intaglio is a 64-bit application and should work well with Big Sur, so Clark’s experience should not come as a surprise. It is a concern that Nick appears to have abandoned his “baby”, and its good to look for alternates, but for now I’m happy to learn that Clark had a good experience. I really don’t want to learn to use another drawing program when Intaglio ideally fits my needs.
That’s great news for Clark but it’s still not working for me. I’m running 11.1 on a 2015 MacBook Pro.
John Whisman
707-694-2380
Clark- still not working for me. Which version of Intaglio are you running?
John Whisman
707-694-2380
Hmm, I really hope this is the beginning of a solution, but here Intaglio 3.9.5 on MacOS 11.1 launches but then does not open either a new file or an old file…
Ha, just after I posted this negative result, I clicked around a bit more, opened a “new workspace”, and somehow now it works, windows open, new and old. I’m unsure how this happened, but it is great news in these dark days!!!
Sorry to hear not everyone is having the same luck as me. I’m running version 3.9.5 of Intaglio. It shows on my disk as taking 18,820,943 bytes and a “Modified” date of Oct 17, 2017, don’t know if that means anything vis-a-vis revisions. I’ve used it a good bit more since I first posted and everything I try works. Happy to help others to get the same results, but there’s not much more I can think of. Sorry if I’m stating the obvious, but in a similar situation I would try disabling all system extensions, restarting, and try running Intaglio as the only open application. That’s not what I’m doing, but it might uncover the problem.
Thanks a lot for sharing your experience and your willingness to help Clark. We all appreciate it!
John Whisman
707-694-2380
I tried it on a second computer, which I had not yet upgraded: installed MacOS 11.1 , held my breath and … yes, Intaglio opens as it should. What a relief…
Thanks Carlo. What is a “new workspace?” Is that something I access from the Finder, or from within Intaglio once the app is open?
John Whisman
707-694-2380
