Hi Doty,
The Mals Actions are designed to handle pretty much any combination of
items that you can think of when setting up your buy forms. The
downside of this versatility is that you need to stop and think for a
while how best to break the products down so they make the most sense
for the buyer (and you).
In your example (below) I would split the garments into the four
distinct product forms (mens & youth short sleeve, women’s short
sleeve, mens long sleeve, and hoodies). I’ve chosen mens & youth short
sleeve as an example of how I would approach this and the other form
items.
Here’s the (very basic) example;
http://www.freewayactions.com/test/mals/index.html
First I sketched a standard HTML box to the page and applied the Mals
Buy Form Setup action to it. This action will define the base store
properties and a default product for the box (this will get
overwritten in this example but it is good practice to add it anyway).
Within this HTML box I’ve added a standard Menu/List item (labelled
size). This has the Mals Multiprice Select action applied to it as the
price varies depending on the size of the garment. Add the products,
descriptions and prices to the action.
Below this we have another standard Menu/List item that holds the
color information for the shirts. Now because the color doesn’t change
the price at all we can simply add the color as a note to the item in
the cart. Simply name the menu item in the inspector palette
‘product1[]’ (without the quotes) and the selected menu item will get
appended to the product description in the cart. If you called the
menu product2[] then it would add a comment to the second product in
the form, product3[] for the 3rd, etc, etc.
Lastly you just need to add a standard submit button to the form and
you are set.
The second example is exactly the same as the first but I had a play
with a bit of JavaScript to swap the images over when you change the
shirt color in the menu. It is all hand coded and because of this is a
little fiddly to set up but you should be able to see how most of it
is constructed.
http://www.freewayactions.com/test/mals/example2.html
I’ll send over the example Freeway 5 Pro file to you in a separate
email.
Let me know if you have any questions.
On 2 Nov 2010, at 20:58, Doty wrote:
Thanks for jumping in on the discussion. I am using your actions.
You can see my work in progress here:
http://dotyshepard.com/shop/bike.html
There will eventually be 30 different pages with different
characters, bike, hike, hunt, etc.
The shirts are the hardest part. There are four styles: mens & youth
short sleeve, women’s short sleeve, mens long sleeve, hoodies (adult
& youth). Not sure how much detail you need. For example mens & kids
tees: YM, YL, YXL, AM, AL, AXL, AXXL all are $16, except xxl which
is $18. Sizes and variations are similar for all four styles. Is
this the kind of info you were wanting?
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
