On 7 Dec 2013, 4:34 pm, waltd wrote:
Forgot to mention: this only will work on an HTML5 page, so this trick is Freeway 6+ only.
On Dec 7, 2013, at 12:24 PM, Walter Lee Davis wrote:
Here’s something else for you to try. On a new page,
Hi Walt,
I’m using Freeway Pro 6.1.2.
Your latest formatting suggestion provides a more effective means to keep the button and search field box together, but creates other problems, as noted below. I feel like I’m aging prematurely trying to sort this out.
The suggested formatting is a bit more consistent between Safari and Firefox from a Search Field size and relative positioning of the button perspectives. However, in Firefox the Search Field box is a rectangle with square corners and in Safari and Chrome the box has rounded corners.
Here’s a link to a page with the Search elements as per your latest configuration: http://test.advancedbarefoot.com/searchform3.html This page has the Additional Javascript Library text added into Protaculous 2 Action, as well as the External Style Sheet and PHP Make Insert Actions applied. However, the Protaculous 2 Action on this page appears to create a conflict with the Protaculous 2 Action on the http://test.advancedbarefoot.com/searchtest.php page (the Search elements disappear from the page). Strangely, the on the http://test.advancedbarefoot.com/searchtest.php page (the Search elements disappear from the page). Strangely, the Protaculous 2 DOM Loaded Observer on the
searchtest page is calling for the http://test.advancedbarefoot.com/search_form.html page and not the searchform3 page.
If I remove the Protaculous 2 Action from the searchform3 page the Search elements reappear on the searchtest page.
I’ve created 2 additional pages with slightly different formatting applied to the search elements:
The original page: http://test.advancedbarefoot.com/search_form.html (here the search field element “Type” is set up as Text and the box shows square corners in both FireFox, Safari and Chrome) However, in Safari and Chrome there is a large space between the search field box and the button.
On another page: http://test.advancedbarefoot.com/searchform2.html (here the search field element “Type” is set up as Search and the box shows rounded corners in Safari and Chrome and square corners in Firefox. Again, in Safari and Chrome there is a large space between the search field box and the button.
I prefer the square corners on the Search Field box.
Am I to gather that there is no way that Freeway will be able to read the External Style Sheet “SearchBox” code while the PHP Make Insert Page is applied?
Thanks.
Best regards,
Roy
