Are all of the users at the same permission level? (User can administer this computer - checked or not)
It could be that the file you are trying to save is owned by a different user, and because you’re not an admin, you can’t override that. If you use the Finder’s Get Info command on the document, what does it say the owner is, and what privileges are granted to other users on it? In my Mac, picking a file at random, at the bottom of the Get Info inspector panel, I see:
waltd (Me) Read & Write
staff Read only
everyone Read only
Is that the case for you (name differences aside)?
On Nov 27, 2017, at 6:43 PM, Leif Halvard Silli email@hidden wrote:
Hi Jeremy and others,
it seems to me that things move in the wrong direction. I have not have had file system issues after I upgraded to MacOS 10.13 High Sierra. However, apparently, after I upgraded to 10.13.1 - something which did on 7th of November, Freeway refuses - or is refused - to save files.
When I think about it, however, I think the issue did not occur immediately after the upgrade. Also, the issue is only in one of my the accounts on my computer (I have added several user accounts … to separate certain projects of min from each others {or, if you wish, the split is result of overthinking}.)
For instance, the account from which I write this email, in that account, I do not have this problem.
Anyone have any idea … ?
Leif
On 17 Nov 2017, at 11:49, Jeremy Hughes wrote:
We’re waiting to see if Apple fix the problem before we spend time looking into ways of getting around it. They’ve introduced similar problems in the past and fixed them eventually. There have been hints that this problem may be fixed in a future update.
High Sierra also introduces a whole new file system, although they pulled some of it shortly before it was released. It doesn’t currently support fusion drives or hard drives - you can use High Sierra with fusion and hard drives but you can’t use the new file system with those drives. That seems half-baked to me. I’m sure it will be great when they’ve ironed out the problems.
I think it’s generally sensible to avoid upgrading to the latest macOS (whatever that is) until it’s been through at least a couple of updates. Unless you have to, for some reason.
Jeremy
On 17 Nov 2017, at 10:06, Paul email@hidden wrote:
No word from Softpress as to when or if they’ll be addressing this issue. I’ve not upgraded my main work machine yet because of this problem. You’ll need that checkbox if you’re doing responsive work and are importing images.
