I am trying to enhance a site to include Mals E Commerce shopping cart.
I have created a simple table of items and in one of the Cols i plan to put the “BUY” button associated with the item, to get the Button i select the table cell and get the insert flashing icon and then choose Form Item > Button, once the Button is inserted i apply the E Buy Button Action, the issues i have are:-
When i view the page on a Browser if i Zoom In the text in the button resizes but the background of the button does not.
Is there a way to change the background of the button to match the background of the page? and to change the color of the text within the button. if i can fix this issue then the first problem in 1, above will not be so noticeable.
I need to correct some parts of my initial post please read the following:-
ref the above and the words
“i select the table cell and get the insert flashing icon and then choose Form Item > Button”
should have read.
“i select the table cell and double click inside the cell to get the “flashing Insert icon” and then choose the Insert > Form Items > Button”
Interesting…i am mainly using Chrome to do the initial testing, so the error occurs under Chrome but does nto under Firefox.
All i am doing is displaying the page and then Selecting CTRL & + to zoom in and i get the button text and image react in different ways, the text seems to enlarge and the button does not.
According to the Freeway reference you need to insert a standard Button before you apply the E-Buy action i was not aware that you can use any Graphic.
Yes the button at the top of the cell is another problem as i have set the style up with the Vertical Align set to middle, which works for all other cell data.
I may just give up on this one and use the E Buy Text Action which i have more control over as seen in the 5th option on the page which is enabled with this Action.
Sorted, i had the table cell vertical align set before i inserted the Button, I assume that what was causing the issue. I still have the Zoom issue on Chrome though.
How do i copy an image into the Forum response? i can show you the end result.
Post a link and lets look with a range of browsers but if it is only really evident when zooming with Chrome 23 I am not sure I would be wasting any time over it.
