It sounds to me as though you are trying to continue with the iframe here, and have put the Carousel on a page which you then include into your main Projects page. Stop that! Now! You are needlessly complicating things for yourself, and also making a page which cannot be linked to from the outside world.
It was like a seen from Moonstruck… “snap out of it”… slap
Heh. I did smile when I read his post.
I’d add that you should do your best to avoid using iFrames at all
times; always see if there’s another solution, a different design
idea, ANYthing other than iFrames!
Sometime around 10/2/08 (at 16:32 -0500) Carla said:
Yes I realize that now… I will go into the action folder and dump them.
Well - I have to say I still have the actions around. It is just that
it should normally be a last resort solution. That’s all. Sorry for
the confusion!
Glad you are sorted - sorry I wasn’t around much this W/E to help you out but you were in the expert hands of Walter and Keith.
But PLEASE for the future get yourself some webspace that you can upload your test sites to so that we can see the problems (and read your code of course).
Very often this is all we need to give the correct guidance.
