When you say you want to put another Carousel on the page, do you
want it to appear below the first one, like my example page?
If so, then that’s as easy as selecting the first Carousel group and
option-dragging it down to copy it, or selecting Item > Duplicate
from the main menu.
Then use the Site panel to move through the individual panes of your
carousel and change the images and text therein.
If you need there to be a different number of panes to one of the
carousels, then I would do the same thing, but then ungroup
everything, delete all but one pane, and then work up from there
using Item > Duplicate to keep cloning panes in place.
Then go through the steps of grouping, adding the action, adding the
controls, and then finally grouping the controls with the carousel
group.
I agree with others who have pointed out that six carousels on a
single page is going to be very heavy, leading to long load times and
potentially users leaving before the thing has finished loading.
Now, as far as your link navigation goes, you will be able to make
text links in HTML to cause individual panes to appear, but they
won’t scroll into place smoothly. For that, you would need to use the
Carousel Tabs action on graphic buttons. Give it a try, it’s how the
tabs work on my demo, but of course the tabs don’t need to look like
tabs – and they don’t need to be along the top. You can put them
anywhere as long as they are grouped with the rest of the carousel.
On Feb 9, 2008, at 3:50 PM, Carla wrote:
Well it seems I need more help…
I made a great 1st Carousel on page, now I am try to make my 2nd,
and created a new HTML box right on top of it. It seems this is
incorrect. Please advise…
I will need to make 6 separate Carousels on one page, as each one
is a new subject matter.
I will worry about linking the menu to these carousels later.
