carla
April 17, 2012, 2:51pm
1
Hey all
I am trying to align the caption on my showcase thumb to line up with edge of image instead of centered.
Thanks for help
here is link
http://www.carlagrande.com/test1.html
I cant see that this is going to work as the captions appear too long to fit.
You can certainly style them.
carla
April 17, 2012, 4:34pm
3
Hi Dave
I see that
maybe if I can make smaller font it would make a difference.
How would I change the size?
Thx
You can add a style to your FW page to overwrite the existing caption style.
Try this - Copy the following and paste it into Page>HTML Markup in the Before section.
<style type="text/css">
.fwShowcase_caption {
text-align: left !important;
font-size: 10px !important;
</style>
The size of your standard caption is 12px. Adjust the size to suit. I have suggested 10px.
carla
April 17, 2012, 11:52pm
5
thanks Dave!
carla
April 18, 2012, 1:53pm
6
Dave
all is good now. Instead I took caption out of the equation all together and put the names separate so they would stay where I wanted. The other solution moved both names, but thanks for advice. I will be able to use another time.
I have one more strange occurrence with scripty accordian and Firefox. The main menu is another font, bolder than the drop down. I used Web Fonts action and it works great in all other browsers except Firefox. Is there a fix for this?
take a look when you have a moment
http://carlagrande.com/test1.html
I think your problem with the captions was really because your thumbnails are so small.
Haven’t looked at the other issue yet but what I do see is poor quality text in Safari - very bitty
carla
April 18, 2012, 7:06pm
8
I know
Is that not more of an issue then?
I see this in your CSS
font-family:Quicksand Book;
should it not be
font-family:“Quicksand Book”;
carla
April 18, 2012, 8:54pm
11
Hi D
hmm
I checked where I could put the quotes for the font. Both in Inspector and the Style where we used Extended to get rid of bullets The new font family is a drop down menu with no quotes capability…
where could I put the quotes?
font-family:”Quicksand Book”;
thx
Did you create a new Font Set. Edit>Font Sets
carla
April 18, 2012, 11:25pm
13
Hi there
yes I did in Inspector, create a New Font Set, and called it Quicksand Book
But did you put ”Quicksand Book” in the alternative fonts section ie
”Quicksand Book”, verdana, arial, sans-serif
carla
April 18, 2012, 11:38pm
15
No but I will
first I have heard of this so thanks for letting me know. I have done research on this but did not find anything
thanks Dave
C
This page uses your fonts from your site linked to my page
http://www.deltadesign.co/fw_examples/quicksand.html
carla
April 18, 2012, 11:52pm
17
Great
working on it now, will let you know before I delete page. so appreciate your help Dave.
Note that my page wont work in FF because the fonts are on a different domain (yours) to mine. FF apparently doesn’t like cross domain stuff.
carla
April 19, 2012, 12:02am
19
have a bit of time of this because I am also using web fonts action , embedding eot and ttf
in addition to creating Font Family with “”
is this a conflict?
carla
April 19, 2012, 12:09am
20
Dave ugh
all fonts on entire website are kaput! not working. gone back to helvetica
