I want to create subdomains for a couple sites I am doing - the photo galleries for starters - but I am not sure how to handle this in FW4Pro. (I have the 5 upgrade purchased). Right now I have one gallery page that is gallery.html and an iFrame inserted for the flash show. How would that page translate to the subdomain?
What I think you’re after is probably just a folder within your
regular site, not actually a sobdomain at all. Just make that new
folder in Freeway’s Site panel and drag pages into there. Upload, and
you’re done.
Great - that helps. I think it might be useful in the near future to tell clients (or mine or otherwise) to get info on a particular spot if the subdomain is given - dedicated spot rather than a subfolder of the existing site. One you often see is support.site.com kinda thing. So a gallery could be gallery.site.com for quick reference if need be.
If I have a FW folder created “photos” and then on my server I have the subdomain photos created - would the folder from FW automatically configure to access those pages as the subdomain? Or would those folders appear as site/photos/…
A subdomain is only ‘sub’ in the sense of the domain name structure
hierarchy. In the sense that you’re considering, it is an entirely
different place. In the simple sense it is a different domain.
Although a document can contain folders and upload that folder
structure and contents, you cannot have one document upload to two
different domains.
Folders are the way to go if you want to keep things simple. www.site.com/photos rather than photos.site.com.
Anyway, SO many people assume that a web site absolutely requires
‘www.’ that they’ll tack it on the beginning and try to visit www.photos.site.com - which wouldn’t work unless that was set to map
to the one without the www part.
Subdomains can look nifty and important and they can be useful, but
they can also lead to confusion. But on the other hand they can also
be useful to split things up into more self-contained site parts.
On our hosting, each sub domain you add you also have full email capabilities, for example you could have an email box, forwarder, catch all forwarder or autoresponder on email@hidden
Abslutely; there are uses. Although other ways to tackle that could
be htaccess redirects - or just a different approach to folder
structure logic.
Also, subdomains have to be treated as entirely separate sites
altogether when it comes to FTP uploads. I’ve yet to see any site
creation tool support file management across multiple subdomains.
And there’s still the issue of people not understanding that www is
actually a subdomain itself, not something magic that is required
‘for a site to be web’. I regularly notice people having trouble
visiting subdomains because they add the www. on in front when it
isn’t meant to be there.
One of the hosts that I use (Modwest) has this handy automatic Folder
== Subdomain trick in their hosting. If you create a folder in your
htdocs folder (which is not the same thing as your site folder) then
a subdomain is automatically created in your account. A vanilla site,
set up for http://example.com would have a folder structure like this:
/htdocs/_ is an alias which silently routes domain-only requests to /
htdocs/www
If you add another folder called /htdocs/foo, then you can navigate
to it instantly at http://foo.example.com
It’s a very nice setup, and here’s where this gets even more
interesting for Freeway users. If you create folders in your Freeway
document called www and foo, and move the appropriate pages for each
site into those folders in Freeway, and set your Upload preferences
to go into htdocs rather than htdocs/www, you can upload to two
different subdomains at the same time from one Freeway document. Kind
of the reverse of having a bunch of Freeway files uploading in the
same site!
DANG, that’s clever.
I just tested this on my Dreamhost account. I can do everything you
mentioned, but it looks like the initial subdomain folders need to be
set up first - not surprisingly, so they’re added to the DNS. The
automatic folder setup trick is the missing step here, but it isn’t
hard to get past that bit by setting those up first.
Proper multi-domain management from a single site document, just like
I said wasn’t possible… thanks for the info!
Walter, that sounds really cool - if I follow it correctly. My head hurts LOL. Are you saying I can setup my folder structure at siteground with that and disregard the public_html folder? (I get the part where the FW file folders would only work when the subdomain is created with siteground first)
No, I am just relating that Modwest has this cool feature. I have
never used siteground, so I can’t speak for them.
siteground first)
You’d have to do some tests first, but in my tests with Dreamhost it
seems that if I set up the subdomain first, then make the
correctly-named folder at top level in the Freeway document’s Site
panel, and then upload to the place where those folders can be
seen… the data will be put into the right folders automatically.
And just work.
I’m creating a mobile version of my site. My understanding is that if I create a subdomain with “m” as the subdomain, then mobile browsers see that as the site. (For example, www.m.MySite.com)
Based on that, and reading through the stream here, it would appear that I first have to go to my hosting provider and get them to create an “m” subdomain? Or is that something I do in Freeway?
Just by calling it m won’t automatically make a mobile device change
to that URL.
On 12 Jun 2010, at 18:26, “Jamie Turner” <email@hidden
wrote:
Hi, Folks –
I have a question regarding subdomains.
But as David says just calling your site m.yoursite.com does not make it the default for mobile browsers.
It is recommended that you use a subdomain but what you call it is neither here nor there - it really is to differentiate it from your normal site.
And remember to use the iPhone/iPad redirect action to bring those mobile users to the correct pages and especially direct them away from Flash content to an alternative.
After a long delay, I’ve finally added an m. subdomain to my existing site via my hosting provider (GoDaddy). In other words, GoDaddy has installed a folder on my hosting account called “m” which is a subdomain to 60SecondMarketer.com.
DeltaDave says the next step in this process is to create a corresponding subfolder in my FW document. I know how to create a folder in Freeway, but I don’t know how to create a subfolder.
