Hi sorry for not very quickly responding , but I was away on holiday.
Ok… version 1 of the WebYep system works from version PHP 5.6.33
version 2 of WebYep works from 5.4 up to the latest 7.2.7
So yes it was huge amount of work to make WebYep work in php7
a lot of code had to be rewritten
all the older WebYep actions for freeway: 3, 3.1, 3,2 eat are intended to be used with version 1 of the WebYep systems
The new (not released) 3.5 version works for both older WebYep systems and the new version. Again as in the WebYep system itself a lot had to be rewritten
I will be launching the new WebYep actions for freeway the minute I get settled back into work
As a side note version 2.1 o WebYep system is also finished it contains a new language (Spanish) and we have squashed some bugs which we found in version 2
I should have checked what I wrote
Version 1 of the WebYep system works from PHP version 4 to PHP 5.6.33
Version 2 of WebYep works from 5.4 up to the latest 7.2.7
Max
Hi
you download the zip folder which is done by clicking on the green button names clone or download and choose download
then that will download a master folder
inside that is a folder called webyep-system
and thats what you will eventually upload to your server
if you intend to run webyep 2 then I will need to send you the beta webyep action so I will need your email address so could you send them to me
cheers
max
Hi
cheers
max
Hi Max, thanks so much! I haven’t used Freeway for a while but I will need to do need to do some updates at some point. I contacted David Owen (ineedwebhosting.co.uk) about Freeway’s compatibility with PHP 7.0 and he recommended I contact you for the release of WebYep 2 as it’s compatible with PHP 7.0
