Would it be easier to sent me an example that I can use going forward? That way I can learn from it or use that code on future sites. I have many clients that love being able to edit their slideshows on their own.
I could use Owl but clients can’t add elements with a loop.
Billy
Wondering how to do the following:
I have a gallery made up from a four column Backdraft responsive module, each column containing a WebYep 2 image placeholder, with clickable thumbnails to give the lightbox facility.
As it stands, the thumbnail images display the images from the top down and are cut off at a predetermined depth, as the client wants to avoid images of differing heights appearing in the same row as far as possible. This predetermined height adjusts with break points to avoid letter-boxing the images.
Is there any way I can centre the images vertically within the allocated space? I’ve tried various suggestions found on the web for centering images vertically within divs, but nothing seems to work.
The work in progress site and gallery page is here:
Hi everyone.
I am just updating the status of “were the WebYep2 freeway actions are”.
As you are probably aware, WebYep2 launched a few months ago, and I was going to follow that up (after a short test period) with the commercial version plus the freeway actions.
The good news was working with the WebYep community we’ve uncovered just a small handful of issues which don’t affect the normal usage of WebYep system, and of which most have been fixed in the latest betas. While I was doing that, something did dawn on me, that’s specific to Freeway. The hurdle to overcome is between freeway 6 and freeway 7, and how both applications handle styles.
So my big question is:
How many freeway users who use WebYep and use WebYep loops are using Freeway 6
if the answer is not many, then that may mean I change the way I handle the styles within loops
Any feedback would be appreciated
max
mmm ok from the response it looks like most people have gone over to 7 which makes things easier
cheers for your feed-back
As a side note:
WY 2.1 will soon be launched
it has the bug fixes squashed and a whole new language installed
which is European Spanish
it will also make send to finally realise the WebYep freeway actions as well at the same time
all the bets Max
Hope you don’t mind me asking but is the WebYep2 available for download anywhere? Hope that I haven’t just missed an obvious link in the midst of this thread!
I am using web yep in Freeway 7 with version 3.3 of the action. However I am not able to view all the actions when trying to insert them. Maybe an upgrade might sort this.
many thanks
Remember, all Actions are context-sensitive. If you don’t have an object applicable to that Action selected in the design view, the Action will just not appear in the list when you try to apply it. So for a Page Action, you have to ensure that nothing at all is selected. For an Item Action, you have to have the correct type of object (Graphic box or HTML box) selected. For an Action Item, you have to have either a flashing text cursor somewhere, or nothing selected, in order to Insert / Action Item / [pick Action here].
On Sep 11, 2018, at 8:44 AM, tonzodehoo email@hidden wrote:
Hello Max,
Thanks for your contribution. Indeed I have been using this action set for a few years and am familiar with the setup etc but the only actions available in any elected state are the login button and the Rich text one.
The other actions are not showing in the menu edit-actions list.
I’d set it up on a site built in an earlier version of Freeway and was starting the process of reconfiguring it in Freeway 7 with a view to making it as responsive.
Its frustrating when a wee quick job is met with an unexpected technical issue such as this.
I thought maybe if I could get version 3.4 and do a fresh install then it might at least rule this out as a possible reason.
Thanks again and hope you are well.
For future reference I had the hosting company downgrade the php version from version 7 to 5.4 and the page is working fine.
I assume that its a lot of work for Max to rewrite the script to be able to work in the most up to date php version. I was just curious what the advantages of with the more up to date version as opposed to the older versions?
Every day is a school day so if there is a way to understand this more it would be interesting.
Thanks again
