What colour is the box you are drawing? Is it the same colour as the background? if so, its not actually cutting a hole, just looking like it.
On 11 Jan 2009, at 5:56 pm, SkipII wrote:
I cannot think if any clearer way to describe this that to say the box I draw is cutting through the middle color layer and exposing the page background color on the site.
Please humour me and tell me this: what kind of box is it that is
cutting through? Graphic or HTML? Select it and look at the Inspector
palette’s title…
Don’t want to color it – it may at times be on top of a gradient. Need it to be transparent background. > On 11 Jan 2009, at 17:56, SkipII wrote:
I don’t know if this is the fix, but have you tried giving the box a
background colour using the Inspector?
Right I’ve got it, I can recreate this problem when working with the CCS button off (Table layout)
See the Big CSS button on the top right of the window? Make sure that is on (it will turn blue and say CSS layout).
If you re-create your steps with this CSS button on, the hole won’t happen this time.
"Okay – delte the gray box. Problem solved.
No, there is no gray box. It is a graphic box I have drawn where the base background color gray is showing through the middle layer (tan or black as the case may be).
I would recommend you working with the CSS button on. It makes a layer of each item you create. You can then move that layer up and down to overlay other items, to make your page makeup easier.
There are other issues you will come up against when drawing a new box over another existing CCS layered item. But its good if you get comfortable with creating, moving and stacking CSS layered items to start with.
CSS has been on the whole time. Never turned it off.
happen this time.
Sometime around 11/1/09 (at 14:41 -0500) SkipII said:
CSS Inspector…CSS Inspector…looking all over for the CSS Inspector.
Psst… nobody said “CSS Inspector”!
There’s a big “CSS Layout” button in the buttons along the top.
(Unless you dragged it out - see my note about customising and
restoring the button bar.)
When this button is blue then new items you make are layered
(CSS-positioned) by default. When the button is grey then new items
are not layered by default.
This doesn’t affect anything else; it doesn’t change the
layered/not-layered state of items you’ve already made. THAT is done
with the “Layer” checkbox in the Inspector, object by object.
Could you not give it the background colour you want it to have? If
it’s transparent, it won’t have any colour. You’re finding that it’s
cutting through the one who’s colour you WANT it to have, and showing
the background colour instead. Can’t you just give it the background
colour of the one you want it to be?
Okay, this has gotten way too complex. If everyone who really has been incredibly responsive on this can just take a deep breath, this is my last try at this. I am about to say everything on this:
I put a gray background ont the site – not an object, just the backgrond color that you are given the option to do so there is some color that covers the area in browsers that exceeds the actual page area. This background is gray.
WITH THE CSS BUTTON ON, I then created some page areas – one is black, one is a white and tan jpeg. These are graphic elements, not HTML and not layered. Done according to the instructions.
I then drew graphic boxes on several areas of the site to insert text. These are NOT HTML boxes. There is no color selected for the graphic boxes.
The ENTIRE area of these boxes – bordered exactly by the edges of the boxes – is gray --the EXACT same color of the base background color, as opposed what should be the black or white/tan color of the page colors.
Again…these are graphic boxes, not layered, not HTML. I can type in the boxes, but any area of the box other than the type itself is gray.
Take ourselves out of tech mode, for a moment please. Imagine you were cutting out cookies on two sheets of colored parchment paper – the parchment paper layer on top is tan, the one underneath is gray. You cut out the cookie and expect to see the first tan layer of paper, but instead you find out you cut too deep and you cut right through the tan latyer of paper as well and now the gray paper is howing.
THAT…is what is happening.
As a result, I have a site that looks fine in page view but when i preview it in the browser, ALL of the areas where I have created a graphic box are filled with gray.
38 posts on this. I don;t know what I can do to explain it better.
