WebYep 2 released.. Freeway actions will be launched in the next few days
Hi Max,
when will the new Freeway Actions will be available and the long waiting is over?
Hi Max,
yes, the acute accent works.
Thanks again.
Alain
Hi purity could you send me your email address so I can contact you directly
cheers
max
Hi Max,
I’ve just sent you a mail :wink:
Thx
purity
Thank you so much Max!!
Hi Max
I have got to the bottom of the error message I was getting. The website hosting needs to be on the latest version of PHP and then it works fine
Kev
the minimum php for webyep 2 is php 5.6 i think
Hi Max
Mostly going well. I just can’t seem to get the images to be response:
any ideas on what I’m doing wrong?
Kev
within the webyep image palette
click on the extended button and add this
           style="width:100%;height:auto"
that will make the image responsive within its container. so as long as the container is responsive then then that will work
speak soon max
Worked a treat - thanks Max
Max,
Can you elaborate more on the use of the code snippets?
Billy
Billy
code snippets are for people who don’t use freeway or rapid waiver or if you want to insert the code within a html page by hand
max
Does the WY Slideshow still work with this?
Also can I bring in a data folder from a site I’m updating?
The issue I’m having is when you save in any editor it doesn’t close or save the data. Permissions are set-to 777
Billy
As I recall maybe there a special image element or editor for the WY Slideshow?
Billy
Hi billy you don’t actually need to set the data folder to 777 anymore
that can be left as 755 (normal).
If you are having issues with loops and saving images then I can almost guarantee its a clash somewhere
Do this test:
Create a page and just use the webyep items and nothing else then see if you can populate the items within the loops,
If you can, then its something on the original page which is messing the loops up.
There is a quick way to get around this but for the moment do the test and come back to me>
speak soon max
the contents of the date folder can be used but don’t use the whole data folder its self because the new one contains some extra folders and some json files
ok.
Do I still need the config-file creator on the main folder? I noticed that if I don’t it doesn’t recognize the actions.
Billy
Max,
When I try to delete an image or upload an image nothing happens.
I managed to get one image into the slideshow but its behaving as if the element is global.
Billy
hi billy I have now seen the page and know what your problem is
so send me your freeway page and I will adapt the code
speak soon max
