YAY YAY YAY!!! Freeway import is the best news ever! thank you!
Prices in USD, GBP, and Euros:
Xway: $39, Ā£29, ā¬35
Freeway to Xway upgrade: $19, Ā£14, ā¬17
25% discount for Xway users who donāt have a Freeway serial number.
Hi, Jeremy.
Congratulations on the imminent release!
I assume we just need to keep reloading softpress.com until an X-Way ābuyā link appears? ![]()
āJames Wages
Will there please be video tutorials? Iāve tried a few times over the years to use the beta versions, but I just do not get it. I have been using Freeway Pro since 2009.
Lately, I have been learning the Mac-only WYSIWYG web editor RocketCake and it is pretty cool and there are DOZENS of tutorial videos available for free on YouTube.
Cooooool! Obviously, Iāll be backing the new app with actual wonga⦠because moral support alone wont keep the wolves from the door or keep the lights on!
Hi James,
⦠like repeatedly pressing the button at a pedestrian crossing to make it change faster?
Weāll also make an announcement here.
Hi Robert,
There will be video tutorials, fairly soonā¦
Iām looking forward to the imminent release of Xway.
Itāll be interesting to see how it imports the site I look after, which has been kept going by using Parallels to update it.
Itās quite complex, as it has grown over the years!
Iāll keep you posted as to what happens to the import.
Great work!
Cheers, Steve.
Jeremy, sounds exciting! Iām a 20-year Freeway user, still using Fwy Pro7. Iām hoping to be able to use Xway, with its coming Freeway import feature. But I need your advice.
I can partition my Mac and keep my Fwy Pro7 website ā www.jimfeeney.org ā on the partition using Mac OS 10.14.6 forever. Orā¦
Iām age 81 and pretty low tech. Over my 20 years using Freeway, Iāve cobbled together an effective personal checklist for adding new pages to my website. I follow that meticulously and have had some success (40K monthly unique visitors).
a) Will the Freeway to Xway import be fairly seamless, giving pretty much a ready-to-upload Xway website right away?
b) Or will I need to do a lot of page-by-page labor on my 560 pages one at a time to get it working right to upload to the internet? I should add, I have well over 10,000 internal links. Again, Iām 81 and fairly low tech.
I would appreciate your candid advice. Would you suggest easy option 1) above (the partition)? Or does 2)a) sound like what Xway will do out of the box? [Iām kind of dreading 2)b).] Many thanks for your help.
Hi Jim,
My initial reaction is that you might need to do a fair amount of work on a 560-page Freeway site.
But having looked at your website, I donāt think it should be too difficult for Xway to import. It is already flexible, and the pages I looked at appear to be using CSS layout rather than table layout. Internal links shouldnāt be a problem.
If there are specific problems, we will try to work with you on these.
Xway and Freeway both run under macOS 10.14.6 (Mojave), so you donāt need to partition your Mac immediately.
Thanks, Jeremy. I think Iāll make a run at Xway when itās released, downloading my FWy Pro 7 website and seeing what changes I need to make. Thanks. Iāll keep in touch if problems arise.
Very exciting that a proper version is coming soon and that it can open Freeway documents. As part of that will it be able to feature Exhibeo slideshows?
Hi Noel,
Recent-ish versions of Exhibeo 2 have an export command which allows you to choose between Export to Xway, Export to Freeway, and Export to HTML. You will need to re-export your slideshow from Exhibeo 2, and import it into Xway as a ācomponentā (Insert > Component).
Thank you very much for that. I only realised today that Exhibeo 2 could run on 64 bit. Happy days.
Will Xway 1.0 also run under Mac OS 15.01 (Sequoia)?
Hi Wulf,
Xway will run under any version of macOS from Mojave (10.14) onwards, including Sequoia.
Iāve been running the Xway betas successfully on macOS 13.7 ( my computer canāt be updated past that). Do I understand that the released version of Xway will only run on macOS 14 and above?
Hi Fred,
Xway 1.0 will run on macOS 10.14 (Mojave), macOS 10.15 (Catalina), macOS 11 (Big Sur), macOS 12 (Monterey), macOS 13 (Ventura), macOS 14 (Sonoma), and macOS 15 (Sequoia).
You should be fine with macOS 13.7.
Thanks.
I keep confusing 10.14 with 14.x.
A post was split to a new topic: Uploading from Freeway
